Originally Posted by ImSoAmish
..... I've also had one instance where i had water in behind my caliper piston and that would get hot enough to expand and make the caliper engage seize up. One simple brake bleed at that wheel flushed the water out and took care of that.
Good rationalization, but .... Water is very hygroscopic so any water in the system will be rapidly disbursed throughout he fluid. Even if water stayed a bubble (it can't) and it's coefficient of expansion was higher then brake fluid, the increase in volume would just push the brake fluid through the compensation port in the M/C and into the reservoir.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
