Diesel Forum - TheDieselStop.com - View Single Post - Head gasket failure without failed head gaskets
Old 02-23-2009, 08:01 AM   #14 (permalink)
simonl
Add "oil cooler" to your list. My 05 went exactly the same as yours...pulling the fifth wheel I could smell coolant. If the oil cooler caused the EGR cooler to fail, it is very possible with continued use (like I did) that the coolant gets sucked in the intake, and since coolant does not compress like diesel fuel, it ends up stretching the head bolts. I beleive, had my oil cooler been diagnosed properly the first time instead of just replacing the EGR cooler and sending me on my way, that I could have avoided the dreaded head gasket fiasco. Others may disagree and say that the damage is done to the head bolts immediatly after the EGR cooler fails.
simonl is offline   Reply With Quote
