Old 02-24-2009, 01:18 PM   #3 (permalink)
cdnsarguy
cdnsarguy's Avatar
My Photos: (82)
NO do not adjust IPs with truck running.......
On the housing that's mounted on the top front of the engine where the pump bolts into, There is a small line about 1/4" long stamped into the rear/upper face of the housing just where the pump would mate to the housing. Likewise, on the pump almost at exactly the same spot on the flange of the pump where it bolts to the housing is a similar line scribed into onto the top of the pump flange.
The idea is that when you put the pump into the housing on the engine, and if you have those two marks lined up such that the almost form one 1/2" Long line, then the timing will be close enough that the engine should start and run. This is known as static timing.
Dynamic timing via luminosity is done where a probe is put into the cylinder, and actually sees the light from the explosion of the fuel, and the timing is set accordingly.
Pulse timing is done where a sensor of a timing meter is installed on the #1 Fseries or #3 Eseries injection line at the injector end close to the injector. NOTE Different brands of pulse meters use different sensors and meters, but they use a normal timing light to show timing on the harmonic ballancer.
Some of us set the timing by "ear". This comes from some experimentation and experience.
I like mine so that when the engine is cold, as the cold advance is on, the engine rattles pretty loud, but once the cold advance drops off, then the rattle smooths out and the engine is much more quiet. If you have it too advanced, then it makes that loud rattle all the time, often accompanied by lots of black smoke, and if too retarded, will sound kinda flat most of the time, lack power, and often not smoke at all, or may even smoke greyish/whitish(unburned fuel).
When you are standing at the front of the truck facing the engine, if you turn the pump counterclockwise(top of the pump to the passenger side) you'll be advancing the timing, and obviously clockwise will retard the timing.
Ziggster's info with some additions by me............Pete
Note .... Never move the IP with the engine running, tighten at least 2 nuts before starting.
One thing to realize the timing is relevent to injector break point (fuel squirt) and IP condition (making the pressure)..... if either one is not exactly on, the timing will not be right no matter what you do.
You would need a Vgood IP and matched set of injectors to do it right.
93 F250 7.3 IDI S/C XLT 4X4 E40D 3.55LS, Captains chairs, Tutone Mocha, Leer 48" Hiboy cap, FR & RR hitches, full DeeZee running boards. Factory ordered/delivered Jan 93 has 200K miles 01July09.
Toys: 2006 36' Triple E Embassy coach (powered by Cummins), 18' Sylvan Pro Fish with Mariner motors.
Proud Canadian BOOB man too!!
cdnsarguy is offline   Reply With Quote
