thanks for the tip.Ill disconnect the pump and try to see if any cylinder pressure leaks into the upper filter housing. hey i dont have any scan tools for the ford and i was wondering if there was a conventional way to tell which cylinders are missing? if there is combustion gases getting into the fuel rail do you think all the injectors should be changed. if the injectors are the problem what should the injectors be torqued too. its in 04 but i think there are two different specs for that year. i was woundering how to tell the two generations apart?
