The whole HFCM does not need to be replaced to fix the WIF sensor. Remove the cover plate that holds the drain plug, and you can access the WIF sensor. The replacement sensor comes with a new pigtail that does not have the fuel heater connection. You'll also need a new gasket for the cover plate. Parts are under $100 if I recall. Should be a $100 deductible if you're under the 5/100.
OMC
