Your problem can be caused by a bad ground. Make sure the ground wire is tight at both ends...battery side and truck side. If you have a multimeter you can also test the alternator by starting the truck and running the lights and A/C. Your battery voltage should read 13-14 volts while the truck is running.
2004 6.0 PSD CC Lariat FX4, Bulletproof Diesel EGR Cooler upgrade, Scangauge II, High Idle Mod, Tow Package, Air Lift Bags, 2006 Jayco Eagle 325BHS 5th Wheel
