Diesel Forum - TheDieselStop.com - View Single Post - 05 F-250 stuck in 4 low
Old 03-10-2009, 09:45 PM   #1 (permalink)
jk_diesel
i took my truck off road and put it in 4x4 hi goin up a hill side got to the top and thought i would put it in 4 low so i didnt have to use the brake that much coming down. work great when i got to the bottom it didnt shift back out i tried all the tricks ppl say to do DID IT ALL i took that plat off with the little engage motor on it took it all apart ( STUPID ) i after i did that i thought hey ill put it back together and use a 12v drill battery on it IT WORKED FINE put it back on the truck and tried no work so i thought ill use the 12v battery and see if it worked so i turn the key on put it in nutral got under there and it worked so i hooked it all back up then drove it and thought ill see if it works it engages in 4x4 wont come back out played with it more went in 4 low and wont come back out so i use the 12v battery again to take it out and unpluged the switch on the dash......can anyone tell me why it engages with the switch but will not disengage with the switch
jk_diesel is offline   Reply With Quote
