Diesel Forum - TheDieselStop.com - View Single Post - Hoist for 2000 F 350 shortbed
Old 03-10-2009, 11:22 PM   #6 (permalink)
daveb198
We have have our own shop and have a 10,000 lb lift. I put my 2001 Crew cab dually 8 ft bed on it. Its all about finding the balance point. Also when i raise the truck in the air i put a 4x4 under the rear reciever hitch and lower down the truck a little bit to take some weight off the rear arms.... I have pics in my signature below of my trucks on the lift. Also since you are going to use it for your truck I would recomend getting risers that go on the pads of the lift arms. You need them especially if you have running boards. You can use blocks of wood but these trucks are heavy and can slip on the boards.
2001 F350 Lariet CC dually 4x4 7.3L Powerstroke w/4:10's Two tone black and gold. Mods so far
AFE STGE2 Intake/ITP KCM S.S. HPX Line/Foil delete/ 6 inch bull hauler stacks/dipricol guages(trans temp,boost,EGT)/ Ported turbo shroud NON-ATS/
DP-tuner F5 (No-start,Stock,1500 high idle,40 tow,60 tow, 80E,120 race, 140)
"SOLD" 1985 F350 Crewcab dually with banks
wastegated turbo and gearvendors under/overdrive. 3.54 gears
TRUCK PICS
http://good-times.webshots.com/album/561388510jqoIof
daveb198 is offline   Reply With Quote
