Diesel Forum - TheDieselStop.com - View Single Post - 04 wont crank with the key
Old 03-11-2009, 05:06 AM   #2 (permalink)
macmaniac1
if you have an automatic then check your park/neutral safety switch under your dash. I had this problem on my explorer and found that one on the bolts holding the switch in place had worked loose. This wasn't allowing the switch to make full contact and was causing a no start situation. Hope this helps!
macmaniac1 is offline   Reply With Quote
