You don't have to drop the tranny pan to change the 7 to 8 qts. in it. there is a drain plug. The filter in the tranny pan stops trees and boulders and needs to be serviced only if the tranny has problems or is being rebuilt. Do change the ext. tranny filter every 10 to 15,000 miles. Engine oil is every 5,000 miles or 6 mo. whichever comes 1st. Do use Racor or Motorcraft filters only. Fram CH9549 is a repackaged Racor. Use only Mercon SP in the trans.
