Diesel Forum - TheDieselStop.com - View Single Post - Injector replacement - with pictures
Old 03-11-2009, 08:05 PM   #14 (permalink)
chrisgabe
You Might Try Hot Shot's Secret
Originally Posted by jrep57 View Post
I saw your injector article and I was not able to open the pictures for some reason. I'm having injector problems and would like to work on them my self. Are there any manuals I can buy to read up on the injector replacement?
Hi Guys,
Just wanted to jump in here and say hello and mention something..
We developed a product called Hot Shot's Secret to address the stiction problem which is the primary cause of injector failure in the 6.0
It was tested by International and found to correct the problem an amazing 86% of the time and improved the performance for the remaining 14%.
If you suspect failing or failed injectors as the root cause of your performance issue...we suggest running through a treatment of Hot Shot's Secret before replacement.
Good luck with the injector issue.
Dan
chrisgabe is offline   Reply With Quote
