Old 03-12-2009, 06:44 AM   #63 (permalink)
schoolde
Originally Posted by roreri View Post
I have a Crew Cab now, how would one determine what door is the problem???
My interior lights will not go out and my door ajar light stays on.
I've used up my quota of WD-40 in all 4 doors. If I can't get this fixed tonight, I'm gonna have to unhook my batteries, MUCH easier than pulling a VERY hot bulb.
Thanks all!
RoReRi
Found the problem... FYI...
The interior and bed lights finally timed out.
Opened each door and then let the lights time out again, takes about 5 minutes, but seems like 30.
After the two back doors I tried the drivers door.
Culprit was the drivers door. When I opened the drivers door the lights did NOT come back on.
Maybe this trouble shooting method may help someone.
Thanks all!!!
This worked like a charm, thank you so much. It was the drivers side rear, and I had to spray and work the mechanism for a good while, but the lights now function as they should. you are a rock star!!!!
2002 F 350 4x4 Crew Cab Lariat
7.3 Diesel 6-speed manual
173,000 miles
All Stock, Possible Chip?
schoolde is offline   Reply With Quote
