Yeah but you have an IDI hes got a 6.0 ...
Sorry for your bad luck but glad to hear a 6.0 is running on 25%.
Your original question though...yes youcan mix watf(waste automatic tranny fluid) and wmo(waste motor oil) HOWEVER as I have stated MANY times in the past on here. Filter filter filter before you use any wmo--no matter what the source. Rather over filter before use than have to clean all the mess up after the fact.
for instance-- friend of mine bought new house filters to filter a few hundred gallons of wmo he scored. In his haste(he already had an old filter setup) the new filter housings dont come with filters installed. Soooo instead of the 20 mic to 5 mic filtering he was used to the two new water filter housings(empty) pumped 20 gallons into his 01 psd unfiltered... what a mess.
to avoid such things i had suggested always for him to filter into a container first then pump into your fuel tank. His effort to bypass a step to save a little time cost him a lot of headache and effort as well as frustration.
Needless to say I did not have to say I told you so
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
