Diesel Forum - TheDieselStop.com - View Single Post - How many miles on WMO?
Old 03-19-2009, 08:07 AM   #65 (permalink)
jski55
Originally Posted by ta5150 View Post
cjhstang-
Do you switch fuel tanks for startup on 80%wmo? I run 90+%, but I start/shutdown on pump diesel. Whats your setup and how is it workin for ya?
A couple times I have forgotten to switch at shutdown. She starts after excessive cranking, and belches a big cloud of grey!
If you are running 90% wmo its probably a good idea that you are running your #2 before shutoff.
Startup depends on your location and ambient temp. Have run 100% wmo to test many years ago. Temp outside was 90degrees though.
I prefer the two tank setup with one being regular diesel for startup and shutdown. It works great!!
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline   Reply With Quote
