Originally Posted by thecougar
I am still certain that there is a setting that can be changed in the ECU. As between the 250, 350, 450 there are a number of wheel tire combinations and I would find it doubtful that the tire pressure is the same across all options. But I have been wrong before.
As for after market, this looks geared more to shops, but after a quick google search I found this: TPMS tools you can trust from Bartec USA
If you spend some time on the above site, you will see that the tpms pressure settings can be read/changed if you have the appropriate equipment.
  2008 F250 6.4 psd, Lariat 4X4 SC long Box Tow Command, 3.73 LS Nav system Captain's seats(heated) Michelin AT2's,Leer XQ box cover, Step gate etc, etc
2010 Lincoln MKT Ecoboost, AWD, Nav self park, etc.
