Originally Posted by Roosterq
Follow up question here.
If you don't have a spaer tire on the hanger would it be possible to unbolt the wench and remove the security key that way?
I just bought the truck and it didn't have a spare, so I made the guy give me one. the problem was he didn't have the key to hang it back under the truck. I have the spare riding in the bed of my truck, but would much prefer to mount it under the truck. Of course don't want to spend a bunch time and money trying to find a spare tire key.
The way I understand it is if the spare isn't mounted, all you have to do is crawl under and pry the key socket off the winch. Then, assuming the winch is working, you can just crank your spare in place.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
