Diesel Forum - TheDieselStop.com - View Single Post - 04 6.0 No Power
Thread: 04 6.0 No Power
Old 03-24-2009, 07:30 PM   #5 (permalink)
OMCUSNR
Originally Posted by PREDATOR04250 View Post
Also, Has 55k Miles, Changed Fuel Filters, Air Filter Recently Changed, And Has Recently Had High Pressure Oil Pump Changed.... If Any Of That Helps...
3k is a little high, but it sounds like it's doing what the engineers want. In ordr to meet EPA regs, we go t a bit of "dead pedal". The throttle is programed to not add fuel until the turbo spools enough to supply enough air so that black smoke is NOT produced. Usually you should see some take-off at about 2k.
Try rolling into the pedal, or if you MUST have quick response to get thru a busy intersection, power brake it a bit. Stand on the brake & build boost then let off it to shoot thru.
OMC
OMCUSNR is offline   Reply With Quote
