Originally Posted by kb9snp
I am far from an expert. Just guessing. I saw there were no posts yet for you. I am also not sure if your 6.0 has this or not. But if it does i would check the wastegate. I can just imagine while all that was apart, your wastegate getting some exhaust junk stuck in it, keeping it open. Either that or a leak somewhere else. Just a guess from a noob.
kb9snp
not trying to punk you out but there are no waste gate setups on these engines. When EBP (exhaust back pressure) is higher than the intake manifold pressure the EGR induces exhaust gases to the intake manifold. So insense the EGR valve acts like a waste gate. but this would not apply to me sense I have the EGR cooler blocked off at both ends that prevents exhuast gas coming back thru the cooler to the manifold. FYI but thanks for the input it would make sense but the 6.0 PSD dont have a waste gate.
David
