Diesel Forum - TheDieselStop.com - View Single Post - WIF Sensor
Thread: WIF Sensor
Old 03-27-2009, 10:39 PM   #2 (permalink)
OMCUSNR
Originally Posted by jcuevas997 View Post
My WIF, Water In Fuel, light turned on after I washed the engine. I have been reading about the WIF sensor on the fuel pump under the driver side but is there a sensor at the secondary fuel filter assembly?
No.
Drain the HFCM & see if you have any water in the fuel - there will be little bubble on the bottom if you do. If you don't, try to squirt some carb cleaner in the hole the plug came out of to clean the sensor. If it still lights, you need to replace it.
OMC
OMCUSNR is offline   Reply With Quote
