Originally Posted by RatherBNtheWoods
upper thermostat or the lower one?
Where is this second t-stat?
The hot water heater I have has only 1 access panel and is on the front of the unit. Removing this gives me access to the temperature control dial which is centered on the unit.
This appears to be the only adjustment on the heater. The heater itself is less than 5 years old as well.
1997 F-250 PSD crew cab shortbox 4x4 E4OD trans 3.55 gears, aftermarket downpipe EBPV gutted, 20.3mpg, 173,xxx miles
1998 VW JETTA TDI (1.9L turbo direct injection diesel) RC3 CHIP, EGR eliminate, straight pipe, powerplus764 injectors, 53+ miles per gallon! 156,xxx miles
