Diesel Forum - TheDieselStop.com - View Single Post - 4wd Conversion
Thread: 4wd Conversion
Old 03-30-2009, 12:18 AM   #2 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Possibly the cheapest way is to trade your truck for a 4x4. But then you'd have a different truck.
Parts needed would be a tranny tailhousing and tailshaft, t-case, front driveshaft, front axle, etc.
Donor truck can be either diesel or gasser, although the front suspension (springs) would be heavier on a diesel truck, and would be preferred.
Hard or no-start? Check Here
