Diesel Forum - TheDieselStop.com - View Single Post - Carrier Bearing
Thread: Carrier Bearing
Old 04-01-2009, 03:06 PM   #2 (permalink)
BTBBT
My Photos: (19)
I have a press, and it was not easy. I'll do just about anything on my truck, but I would suggest you have a shop do it.
On my '02 they said I had two different sizes of u-joints. If I'm remembering right, it was a 1410 and a 1350. Not sure though.
- 5.0L EFI, AOD, 3.5" lift, 3" body lift, 35" BFGs, Lock-Rite front, mini spool rear, disk brakes, Warn Hubs
BTBBT is offline   Reply With Quote
