teamroper60 you got it right, the frist time you change that @#@# sensor is a pain but the next time should be a breeze. total time for us was 5hrs we had to find someone to cut down the socket after deceiding that was the only solution. the next hangup was the heat shield and lining up the bolts thanks again to ford,be better if it was on studs and you could just remove nuts and slid on and off . if a next time we might try getting truck up in the air to make reaching ICP sensor easier.
