what are the f codes used in stock? how do they differ from b codes ? how is the ride with either?... Since I have the cummins swapped in my ex..I was debating going with a x code front spring instead of v codes, for the added weight.. the cummins only weight 1-200 lbs more then the 7.3. do you have the f code part #? If I go with a rear anti sway bar? I already know to upgrade to the 30mm bar..how do the Hellwig aftermarket bars differ from the ford bar?
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
