Originally Posted by dieselturbo
shifts through all gears but i seem to have to step down harder to get this beast moving.. used to be 2000 rpm now 23-2500. once it locks up in overdrive i have more power and better acceleration. also milage stinks. this is my first winter with this truck. starts at 16 degrees- no problem. but no power . i had a diesel suburban before this -stock - and it had much better acceleration. does this sound like a bad converter or trans. it pulls good in overdrive when locked. thanks andy. yes i know diesels have no power until warm. but this happens warm too. i expected this to be much quicker than suburban.
Are you totally set on limiting your issue to the tranny?
Hows boost? look normal? have you checked you up pipes, intercooler hoses etc?
My experience has been:
low boost, poor fuel mileage, and loss of power= either boost leak or exhaust up-pipe leaks.
If it's more of a loss of power ordeal, the tranny is the last place I'd look.
How about fuel filter? Clean fuel bowl? Smell any fuel up under engine which would signify possible bowl drain orings.
How's the engine valley on top? Dry?
just my $.02 worth.
 y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 190k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
Trailers:
I'm usually towing 1 of several trailers I've built.
15ft car hauler (1000lbs empty; 5500lbs loaded)
26ft deck over car hauler (2000lbs empty; 7k loaded)
36ft car hauler (Was tongue pull; have since converted into 5er'. 4500lbs empty; 14k loaded)
https://lh5.googleusercontent.com/-g...0/IMG_4130.JPG
