Diesel Forum - TheDieselStop.com - View Single Post - bad torque converter??????
Old 04-13-2009, 10:38 PM   #18 (permalink)
xfordtdm
xfordtdm's Avatar
Originally Posted by Mark Kovalsky View Post
There is no way to flush a trans cooler and get all the junk out. If you reuse a trans cooler after a trans failure expect a second trans failure.
This is especially true with the top feed cooler style. The lines input and output from the top of the cooler allowing sediment to never evacuate and fill the bottom. The 6.0 cooler is much larger and the input/ output is from the bottom allowing no sediment to settle.
2001 f250: AFE stage 2, Banks Monster exhaust w/power elbow and bighead wastegate, autometer pillar guages, kcm crossover, ccv delete, ITP over boost annihilator, dp 6 pos stock, 40,60,80econ,100,120, BTS Tranny, FS2500 soot sucker bypass oil filtration.
xfordtdm is offline   Reply With Quote
