Thread: Axle Question
Old 04-15-2009, 09:08 PM   #3 (permalink)
dlblazer
dlblazer's Avatar
Free bump for you. When looking for axles for 4x4's generally the van axles are narrower than the truck axles. I do not know if this is the case here. Regardless, I would expect the frame width to be the same and the spring perches to be in the same spot (only a tape measure can be sure).
Also, spring length could be different (if you want to use the springs). Be sure to measure all dimensions.
New truck: 2002 PSD 4x4, CC, XLT, F350 dually. Air bags, 6.0 trans cooler, Fleetrite ELC, ISSPRO guages, DB HT starter, and much more to come.
Old truck: 2000 PSD 4x4, ext cab, XLT, F-350, auto, V-code springs, air bags, coolant filter, 203 thermostat, Fleetrite ELC, DB Alternator, DB high-torque starter, Tru-cool Max-cool trans cooler, B&M trans temp gauge, 47 gallon Titan tank, IPT pre-pump filter kit.
dlblazer is offline   Reply With Quote
