Front Spring Part # vs Code
Ok, I've just been searching here for spring s codes that match these part #'s for front springs.
F81AADD and #RPN1128 was stamped under the other #.
I am hoping these are snow plow prep springs x codes or similar, as they came froma 1999 F250 XL 4x4 work truck with 6spd and v10 and plow.
I have done sesarches read tons of threads in the searchs for front springs, spring codes, part # etc etc. I also have a 2 vol set of the 2000 ford superduty work shop manual and I can't find different spring part #s in the manual either. The door sticker was removed on this truck in the junk yard..so the sticker is no help. I have the Vin #1FTNF21S5XEA96298
Truck had 79k on it
Here are pictures.
snow plow ? spring and stock 5.4 gasser excursion spring
part # front springs
are the plastic shim / spacers that go on thearound the center bolt available separately?
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
