Diesel Forum - TheDieselStop.com - View Single Post - Kingpin Dana 60 Front Axle swap?
Old 04-23-2009, 08:36 AM   #1 (permalink)
therabbittree
therabbittree's Avatar
has any one swapped in a Kingpin dana 60 Axle into a Super Duty ? the bolt pattern for the rims is one catch.. I think that could be remedied maybe redrill or swap parts?...also the spring perch spacing and angles.. maybe welding a trac bar bracket etc... caliper interchange etcetc.. any one tried it?
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline   Reply With Quote
