Diesel Forum - TheDieselStop.com - View Single Post - Front Spring Part # vs Code
Old 04-23-2009, 08:32 PM   #11 (permalink)
therabbittree
therabbittree's Avatar
yeah I am not sure why they have two different part # s for something the stamped # and the part # .. kinda confusing.. I'm new to fords..vw and dodge don't do that. haha.
I did PM Caryt regarding the stamped # ..hopefully your right and they are early '99 V codes. ha.. It would save me some time and $ etc. I did take apart the B Code set and modified them tonight..it went pretty easy the G code center bolt worked nice, as the B code center bolt had to be cut off it would not loosen up argh..
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline   Reply With Quote
