This little rod showed up on the floor of my truck. I can't figure out what it might have fallen out of. Maybe it's an extra that someone dropped somewhere during assembly and finally (10 yrs later) got out of where it got dropped. That's an "E" clip near the center, and the ends are slightly ball shaped.
I'm guessing something like a seat belt retractor part or maybe a door latch shaft, but everything works like it should.
Any guesses?
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
