Diesel Forum - TheDieselStop.com - View Single Post - Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
Old 04-27-2009, 06:32 PM   #26 (permalink)
rpm1
Originally Posted by dansk View Post
What cluster will fit a 96 E350/
Thanks, Dann
Dann-I think 99-01 clusters will work.
I just did mine. 99 f cluster in my 03 van. Had to repin most of it, some colors were the same, some were different. I was also able to remove the 600,000 mile odometer and install my original 173,000. It just pops out with a little force.
Everything was working fine for a few weeks, but now my voltmeter is acting up. Seems the bumps can get it to jump around. Just to be sure, I tapped into the red/y wire with a multimeter and drove around for a while, and of course it never happened. AE does show 14.0 v when the gauge is going haywire. So something must be loose.
I did have to cut off the top left mounting ear to get it installed. So now there are only 3 bolts holding it in, but it's not going anywhere.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline   Reply With Quote
