Diesel Forum - TheDieselStop.com - View Single Post - Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
Old 04-28-2009, 07:36 PM   #31 (permalink)
rpm1
Originally Posted by Ears93 View Post
RPM,
Did you have to add or remove any transistors or resistors? I think I've got my pin locations figured out on paper. I just need to know where to get the wire for the tach pin location and the info on the transistors and/or resistors.
Thanks in advance.
I didn't have to do anything except move wires around. The resistor deal might only be for the earlier vans. On my van there is a few terminated wires near the brake booster. I think there is aux ac, 4x4, and one labeled cto. The cto wire is the one you want. Should be white with pink tracer.
I will see if I can get the pinouts for a 97 van posted.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline   Reply With Quote
