Diesel Forum - TheDieselStop.com - View Single Post - Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
Old 04-28-2009, 09:22 PM   #33 (permalink)
rpm1
I meant I would post the 97 van factory pinout, and then you would be able to see what wires do what, and where you would have to move them to get the f series cluster to work. Not sure about the resistors, I should re read this thread. I am pretty sure my cluster is working properly.
Originally Posted by Ears93 View Post
When you say you will try to post pinouts for a 97, will that be the stock locations or will that be for the 99 cluster in the 97 van. I have access to Mitcell and ALLDATA so if you have something I can check my work with that would be great.
I have rear earlier in this thread about the resistor and/or transistors being added or removed and would like more info on that. Once I get this info I just have to get the cluster and tackle the job. But, I want to have all my crap together before I start.
Thanks again.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline   Reply With Quote
