Tight Ball Joints?
Anybody ever have balljoints be too tight? I had NAPA ones installed in my 2001 F250 V10 that were getting progressivly tighter. I just got new ones under warranty from NAPA and when i install them they still seem too tight. The last time i did them i didn't remove the sleeve on the upper joint, this time i removed it, cleaned it, and greased it. Tightened the lower one up, them tightened the upper ball joint to 100 ft lbs.
What else could i be doing wrong? This just seems like its gonna be a repeat of the last time around, although this time i did find that both u-joints were binding and i will be replacing them in the morning.
Sorry for the long post, I'm just out of ideas and need some help!
THANK YOU!
2002 F350 CC SB Lariat 7.3 4x4 3.73 LS
Torredor Red, Viper 5701
