I do not know if this is your problem but the ball joints must be torqued in sequence.
It is ball joint manufacturer specific and must be done in sequentially in steps upper/lower.
Per the Ford manuals, for my 2000 4x4, it goes like this.
1st- Bottom Joint: 35 lb/ft
2nd-Top Joint: 69 lb/ft
3rd and final- Bottom Joint: 150 lb/ft
This sequence is also correct for Moogs. Different ball joint manufacturer's may or may not have a specs different than this.
Buy Ford. They're not taking bail-out money.
2000  F250 XLT PSD Crewcab, Longbed, 4x4, Auto, LS 3.73
Ford AIS, Frantz Bypass Oil Filter, Baldwin Bypass Coolant Filter, Fumoto Drain Valve, 203* Thermostat, Stancor
Bilstein Shocks all the way around, Timbren SES (Rear), Bridgestone Dueler Revo A/T 265/75/16
Commander Monitor (gauges), Crimestopper CS-2016 DP II FM Remote Start/Alarm/Paging/Turbo Timer/Keyless
Rotella 5W40 Oil, Texaco ELC Coolant, Mobile 1 ATF Trans and PS
My mods, repairs, and other truck Stuff
