Originally Posted by Dirtcheap
what did ford change on the excursions from 2000 to raise the tow rating from 10,000lbs to 11,000lbs??
As I recall the numbers printed on the hitch and in the manual; however if you have a 2000 then it is rated at 10K not 11K
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished! (never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
