Diesel Forum - TheDieselStop.com - View Single Post - Horn won't stop blowing
Old 04-30-2009, 12:51 PM   #7 (permalink)
FJK1
Just had the same experience on my non-diesel 92 econoline. Horn would blow sometimes when steering wheel was turned. Finally, horn stuck on full time when pulling into Home Depot parking space. I determined it was the clockspring by first removing the steering wheel & disconneting the horn button from the clockspring. Horn still blew constantly. Then I disconnected the clockspring harness at the bottom of the steering column, under the dash. Horn finally stopped blowing. In my case clockspring from Ford was ~$100; air bag, steering wheel, & steering column shroud, lower dash pannel, & ignition lock had to removed to replace clockspring asssembly. Also, one cloackspring harness connector could not be accessed, so I cut 3 leads & spliced into old harness.
FJK1 is offline   Reply With Quote
