Originally Posted by ataboc
What is a "HPOP"? Or an "IP". Is there a place I could use to look up these abbreviations? I know it's easier to use them, but being fairly new at this, I have no clue what you're talking about.
HPOP High Pressure Oil Pump
IP Injector Pressure should be IPS Injector Pressure Sensor or IPR Injector Pressure Regulator They are all part of the high pressure oil system that runs the injectors.
Hope this helps Sound kind of strange untill you get used to it.
Keep learning, it's a good thing..........
