Diesel Forum - TheDieselStop.com - View Single Post - A/C Fan will only work on high
Old 05-08-2009, 08:47 PM   #2 (permalink)
Lightningfast01
Lightningfast01's Avatar
In general the lower speeds go through a set of resistors. High speed is straight 12 volts. In the old trucks it meant your resistor or fan speed block burned out.
2005 F250 FX4 SuperCab SWB in DSG
Buckstop rear bumper American steel!
Daystar baja bar with PIAA Racing 80's
Quad pillar Air, trans temp, pyro, boost
Magnaflow 15954, ATS studs
Transfer Flow 46gal midship tank
Firestone Airbags 2400 kit ViAir 250C compressor
Eaton TruTrac, Rancho 9000's, Skyjacker 1.5" rings
ViAir 380C@200psi, 5gal tank, Siege Anvil train horns say move *****!
Lightningfast01 is offline   Reply With Quote
