Diesel Forum - TheDieselStop.com - View Single Post - tow rating
Thread: tow rating
Old 05-13-2009, 01:54 AM   #11 (permalink)
78Southwind
78Southwind's Avatar
Originally Posted by MotionMan View Post
what did you use to get the rivets out? mine is a rusty mess and the hole is pounded out from rush that is flaking off...which was once metal. They say the hitch is over $500 and labor was $300...thats just wrong. I was thinking of sand blasting it but it should be replaced.
The two torque bolts need to be drilled out. For me this was a very time consuming process. I only dropped the tank about 2" or so and used magnet to retrive and place the bolts. Here's a couple pictures of the process.
Bumper pulled off
Retrieving drilled out bolt and nut.
Dropping the hitch
Comparing the two
2000 Excursion Limited (BUILD DATE
05/31/2000) 4X4, 7.3 PSD, 3.5" LIFT and SuperChip
78Southwind is offline   Reply With Quote
