Diesel Forum - TheDieselStop.com - View Single Post - Shocks and Springs installed - Pics
Old 05-17-2009, 07:14 PM   #1 (permalink)
Jaysom
First off a big Thank You to everyone on the forum, all the information I was able to gather has been a tremendous help in making sure I was able to get the necessary parts and pieces.
Yesterday I was able to finally modify and install the springs I picked up a little while back. I discussed them Here - I was never able to fully determine 100% based on the engineering codes stamped on the springs if they are F, B or C codes? All I can say is that they feel great and the truck drives 100% better.
Along with the spring install, I installed Bilstein’s front and back that I purchased from CaryT. I can say after a 2 hour drive yesterday that the damping of these shocks is a great compliment to the modified rear springs and tremendously better than stock.
While we had the truck on the lift, we installed new front pads, rotors, flushed the entire system and installed new stainless steel brake lines. Unfortunately, I did not take a look good at the entire system and missed the 2 small lines in the rear, so we only had SS lines for the fronts and the connecting line for the rear hard line. I’ll get around to getting the additional small lines for the rear in the near future. The addition of the SS lines makes for a much improved pedal feel.
My Ex is a 4x2 and with the addition of the springs and shocks, it now has a slight rake to it. I’m fine with it and it is not noticeable at all while sitting in the truck or driving down the road. The added rake with help while towing and should allow for a more level ride height while the trailer is connected.
Another added bonus is that now the rear air bags are not always “squished” and appear to be much more functional.
I had previously installed a Hellwig rear sway bar … so, I think it may be safe to say I’m completed with all my suspension modifications.
I know it has been said many times here on the forum, but what a difference all this makes – the truck rides and drives great – like many have said … way did I wait soo long?
Here is a picture – the shade sort of throws it off a little, but I think you’ll get the idea.
J
04 Excursion Limited 6.0 PSD 4x2, Hellwig rear sway bar and Firestone bags.
08 VW R32
Cheetah DSR
Jaysom is offline   Reply With Quote
