Diesel Forum - TheDieselStop.com - View Single Post - F350 08 mod questions
Old 05-18-2009, 11:34 AM   #5 (permalink)
TomB985
Nope.
Originally Posted by 2008 Ford Warranty Guide
Damage Caused by Alteration or Modification
The New Vehicle Limited Warranty does not cover any damage caused
by
• alterations or modifications of the vehicle, including the body, chassis,
or components, after the vehicle leaves the control of Ford Motor
Company
• tampering with the vehicle, tampering with the emissions systems or
with the other parts that affect these systems (for example, but not
limited to exhaust and intake systems)
• the installation or use of a non-Ford Motor Company part (other than
a certified emissions part) or any part (Ford or non-Ford) designed
for off-road use only installed after the vehicle leaves the control of
Ford Motor Company, if the installed part fails or causes a Ford part
to fail. Examples include, but are not limited to lift kits, oversized
tires, roll bars, cellular phones, alarm systems, automatic starting systems
and performance-enhancing powertrain components or software
and performance ‘‘chips’’
Here are the ONLY things that can VOID a warranty:
The New Vehicle Limited Warranty does not cover:
• vehicles that have had the odometer disconnected, altered, or inoperative
for an extended period of time with the result that the actual
mileage cannot be determined
• vehicles that have ever been labeled or branded as dismantled, fire,
flood, junk, rebuilt, reconstructed, or salvaged; this will void the New
• vehicles that have been determined to be a total loss by an insurance
company; this will void the New Vehicle Limited Warranty
• converted Expedition EL Limousines that are not equipped with the
Limousine Builder’s Package (17L) Option, or if the wheelbase is extended
beyond 140 inches, or if the Gross Vehicle Weight Rating
(GVWR) exceeds 9,900 pounds. See important information about Expedition
EL limousine conversion (page 38).
• any other Ford or Mercury vehicles that are converted to limousines.
This will void the New Vehicle Limited Warranty. See important information
about conversions (page 38)
• converted ambulances that are not equipped with the Ford Ambulance
Prep Package, see important information about ambulance conversions
(page 37)
For example, if you installed a DPF delete and a tuner, and then had a problem with your power door locks not working...they would HAVE to cover it, because there is no possible way your tuner and/or DPF delete could have caused the damage.
You can NOT void a warranty just by modifying the vehicle; you are simply liable for damage caused by such modifications. If you don't believe me, read it for yourself!
TomB985 is offline   Reply With Quote
