Originally Posted by therabbittree
there are two small ones fromt the caliper to the hardline on the axle etc..so 2 front calipers, 2 rear calipers, 1 front frame to axle, and 1 rear frame to axle so there should be 6 lines in a kit..I need to order some for my project too any sources?..I'll check with CaryT, maybe get them from him with his bilsteins
Deo
My Ex is a 4x2, so I did had hard lines directly to the front stock rubber lines. Sounds like the 4x4 may be a little different.
04 Excursion Limited 6.0 PSD 4x2, Hellwig rear sway bar and Firestone bags.
08 VW R32
Cheetah DSR
