Diesel Forum - TheDieselStop.com - View Single Post - Front Spring Part # vs Code
Old 05-19-2009, 06:05 PM   #24 (permalink)
therabbittree
therabbittree's Avatar
Thanks TSprGuy. I did just find spring codes in my factory workshop manual.. not sure why I didn't look in the general info section before?, I had just looked inthe suspension section before ha.... oh well ..The work shop manual doesn't list the ratings .. where can you find them?.. Do You know the rating for the V Code, W code, and X codes?... I'm thinking, I still may swap in v or x codes any way.. I checked where my shims end. They end almost exactly where the out edge of the U-bolt shank is.. mummn Maybe I should remake some new ones that are longer..I will update my chart with the info from your post and the workshop manula..the order #s would be missing from a few though.. ha
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline   Reply With Quote
