Diesel Forum - TheDieselStop.com - View Single Post - Front Spring Part # vs Code
Old 05-19-2009, 06:33 PM   #25 (permalink)
therabbittree
therabbittree's Avatar
Heres the updated chart I made up..I took any of the common front spring codes and any that listed an Excursion application from the 2000 workshop manual. From what I had gathered the front #'s are the order or part #....seems some of the Suffix #s in the workshop match the stamped # 's and some do not... not sure why? Any input T SprGuy? ..could you find the weight ratings and add em to the chart ?
Thanks,
Deo
X Codes..F81A-5310-AFA, stamped #3034AFA, Suffix AHD, Weight ?
W Codes.. ? - ? - ? , stamped # ? , Suffix AGD, Weight ?
V Codes..2C3Z-5310-HA, stamped #3C34ADA, Suffix AFD, Weight ?
U Codes..2C3Z-5310-GA, stamped #2C34ACB, Suffix AED, Weight ?
T Codes.. ? - ? - ? , stamped #F81AADD, Suffix ADD, Weight 1,800lb.
S Codes.. ? - ? - ? , stamped # ? , Suffix ACD, Weight?
H Codes.. ? - ? - ? , stamped # ? , Suffix HA, Weight ?
G Codes.. ? - ? - ? , stamped # ? , Suffix GA, Weight ?
D Codes.. ? - ? - ? , stamped # ? , Suffix DA, Weight ?
C Codes.. ? - ? - ? , stamped # ? , Suffix CA, Weight ?
B Codes.. ? - ? - ? , stamped # ? , Suffix BA, Weight ?
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
therabbittree is offline   Reply With Quote
