Diesel Forum - TheDieselStop.com - View Single Post - ADVANCE TIMING or was it Fuel Pump
Old 05-22-2009, 02:30 PM   #3 (permalink)
RoGrrr
RoGrrr's Avatar
Send a message via AIM to RoGrrr
I do have a 7.3 PSD that has electronically controlled injectors. I also have an EDGE controller in it that I know very little about. It was in the truck when I bought it and I really don't drive it all that much. I bought it primarily to plow my lane and pull a car trailer with. I really like the truck but since it only gets about 13 MPG, it's not one that I drive much at all. I keep hearing about the fellas on the boards who get 20-ish and I have plenty of trouble believing that. Sure wish I could get that kind of mileage....
In the meantime, I'm gathering WMO, which I'm filtering thru a PF8 and then a 5 micron house water filter. I plan to set up a receiving tank with an engine oil pump in it to drive it thru the filters. Right now I can only filter about 5 gallons a day and I dump the oil into a strainer in the garage with the filters and drum in the basement - about 6 feet of drop. More pressure should fix the flow rate.
I have several aluminum cross bed tool boxes that I bought at a scrap yard and I am going to use one of them to dump the oil into to start the filtering process. From there, into a 55 gallon drum or better yet, a 250 gallon tank with a gas station filler hose/nozzle on it. I should be all set then.
I was originally going to run WVO but decided against it since the frybrid fella is a real jerk. He and I got into it several times while I was in the process of gathering info and I was READY TO BUY FOR CASH MONEY from him. After he sh8 on his sales counter (so to speak) I decided to simply build my own system. I figger he threw away a $3000 sale. Then my sources for the WVO started getting flakey and I threw in the towel. Later on, I found out about WMO and that's the route I'm going.
I do plan to investigate timing to see if I can improve performance and maybe even fuel mileage.
Rogrrr
I like BIG, LOUD, heavy trucks, light, tiny women, shooting, and BIG glasses of heavy beer (not necessarily in that order, either ).
http://www.youtube.com/watch?v=-TC2xTCb_GU
The little gal I bought my truck from called it her "COWGIRL HARDWARE".
I call it "LURCH" !
96 F250 4WD, 35 INCH TIRES over a inch lift kit, DUAL 5 INCH STACKS (sounds pretty darn good), BLACKed OUT WINDOWS, SNOW PLOW
CENTRAL OHIO
Oh yeah, I LOVE my carbon footprint !
RoGrrr is offline   Reply With Quote
