i will check on my axle tomorov for numbers.
think it is full float axle, if it is then i can just unscrew the bolts at the end and pull it out?
what locker do you recomend for a e350 rwd. i had lock-right on a k5 i had worked fine, local dealer said that lock-right would not be a good choise for a e350 for street use, daily driving.
they could get a arb locker for me. i would rather buy a locker than is automatic, that i dont have to turn it on and off..
i use the car eweryday. just want a locker for more traction at snow and i can burn both tires just not 1 wheel
