Well - Looks like the seal job did the trick - The gauge now shows that at 65mph - the van is making about 3psi - And the gauge actually moves when I roll into the throttle....
In addition to adjusting where the boost line was in the fitting and the RTV sealant - I also threw some Teflon tape on the threads of the fitting that houses the Ferrell. The instructions only said to Teflon between the gauge and the first fitting - Which I did - But apparently it needed more then that....
I'm also gonna throw some RTV on the machined T-Fitting that is in line with the Map sensor... I am not convinced that the press in fitting that the boost line goes into is sealing as well as it should...
2003 E350 7.3 Race Bike Hauler 107K on the clock DP Tuner
(No Start,Stock,1200 Idle,1200 Idle w/EBV,40Tow,60Tow,80Tow,80E,100,140)
3.55 Gears
Auto Meter Gauges
(pyro-trans-boost)
ScangaugeII
Straight Pipe
203 Tstat
Evans NPG+
Timbren Rear SES
Bilstein HD
DieselSite External Bypass Trans Filter
Tech 2 Cycle Cetane Booster Other then that - STOCK
16.73 mpg avg Since Owned
