Updated the chart with TSprGuy's Info:
X Codes..F81A-5310-AFA, stamped #3034AFA, Suffix AHD, Weight 2,600lb.
W Codes.. ? - ? - ? -?-?-, stamped # ?-?-?-?- , Suffix AGD, Weight 2,400lb.
V Codes..2C3Z-5310-HA , stamped #3C34ADA , Suffix AFD, Weight 2,200lb.
U Codes..2C3Z-5310-GA , stamped #2C34ACB , Suffix AED, Weight 2,000lb.
T Codes.. ? - ? - ? -?-?- , stamped #F81AADD , Suffix ADD, Weight 1,800lb.
S Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix ACD, Weight 1,600lb.
H Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix HA, Weight 2,250lb.
G Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix GA, Weight ?
D Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix DA, Weight 1,980lb.
C Codes.. ? - ? - ? -?-?- , stamped # ?-?-?-?- , Suffix CA, Weight 1,780lb.
B Codes.. ? - ? - ? -?-?-?, stamped # ?-?-?-?-?, Suffix BA, Weight 1,680lb.
As for the part # info, I'm not sure. Maybe some one will chime in.
Thanks,
Deo
2000 Excursion XLT 4x4, 12V P Pump Cummins, 0-ringed head, AE G56 6 spd, southbend FE clutch, guages, lazer dv, 370's, Black Vinyl floor, 285 Nitto Dura Grapplers, 4" remote BD Exhaust Brake, 4" exhaust, Working on Twin turbos HX50 9cm and BHT3E 20cm with tial external wastegate, looking for 2008 XL front clip
http://picasaweb.google.com/therabbittree/Excursion02#
2005 Excursion Eddie Bauer 4x4, 6.0L, Rear Capts. Dark Green
1992 W350, srw, dump flat, 5sp, pods
1996 Passat TDI Wagon, worked
